You can view threshold monitor settings.
efa inventory device threshold-monitor list
For more information on syntax and command examples, see the ExtremeCloud Orchestrator Command Reference, 3.6.0 .
The following example shows the current inventory threshold-monitor settings for the specified device:
efa inventory device threshold-monitor list --ip 10.10.10.75 Hardware Resource Configuration +---------------+--------------------+-------------+ | IP Address | Type | AppState | +---------------+--------------------+-------------+ | 10.10.10.75 | hardware-resources | cfg-in-sync | +---------------+--------------------+-------------+ Basic Monitoring Type Configuration +---------------+--------------+---------+------------+-----------+-------------+ | IP Address | Type | Actions | High Limit | Low Limit | AppState | +---------------+--------------+---------+------------+-----------+-------------+ | 10.10.10.75 | bfd-session | snmp | 80 | 50 | cfg-in-sync | + +--------------+---------+------------+-----------+-------------+ | | vxlan-tunnel | | 80 | | cfg-in-sync | + +--------------+---------+------------+-----------+-------------+ | | lif | snmp | 80 | 50 | cfg-in-sync | + +--------------+---------+------------+-----------+-------------+ | | mac-table | snmp | 80 | 50 | cfg-in-sync | + +--------------+---------+------------+-----------+-------------+ | | route | snmp | 80 | 50 | cfg-in-sync | + +--------------+---------+------------+-----------+-------------+ | | host | | 80 | | cfg-in-sync | + +--------------+---------+------------+-----------+-------------+ | | nexthop | snmp | 80 | 50 | cfg-in-sync | + +--------------+---------+------------+-----------+-------------+ | | ecmp | snmp | 80 | 50 | cfg-in-sync | +---------------+--------------+---------+---=--------+-----------+-------------+ CPU/Memory Type Configuration +---------------+--------------+---------+------------+-------+-------------+ | IP Address | Type | Actions | High Limit | Retry | AppState | +---------------+--------------+---------+------------+-------+-------------+ | 10.10.10.75 | cpu | all | 80 | 3 | cfg-in-sync | + +--------------+---------+------------+-------+-------------+ | | memory | raslog | 80 | 3 | cfg-in-sync | +---------------+--------------+---------+------------+-------+-------------+ Threshold Monitor details --- Time Elapsed: 55.652194ms ---
